Mark123412
Sep 17, 2025Tutor
Brand New RS700 terribly slow speeds
Upgraded from a nighthawk RAXE500 to a new RS700. with the old router I would get 890 down 800 up wired. 700d 700u wireless. With the RS 700 I am only getting 300 down 25 up. I’ve reset ...
- Sep 17, 2025
Yes, definitely upgrade then manually to latest version. It fixes some issues. IF, you run into problems like some others. Hopefully you won’t like myself, revert back to firmware you are on now.
Mark123412
Sep 17, 2025Tutor
Firmware is v1.0.7.96. I’ll check for latest.
