Dinner42w_aView
Nov 27, 2025Aspirant
Can LAN interface of RS100 be set to a public IP address?
I have obtained a /29 range of public IP addresses from my ISP. That /29 network resides on the LAN interface of the cable router/modem/whatever you want to call it. At the moment I am using a Zy...
Dinner42w_aView
Dec 01, 2025Aspirant
StephenB CrimpOn Thank you for your advice on this. I took a punt and ordered the RS100 on Amazon since it's easy enough to return stuff to them if it turns out not to be capable of the job.
It arrived this morning and I was able to set the LAN interface IP to a public IP address/subnet with no problems whatsoever.
All that remains is for me to hook it up and verify that I can get the full 200Mb/s upload speed I'm looking for. Wish me luck...
Thanks again!
