Dinner42w_aView
Nov 27, 2025Aspirant
Can LAN interface of RS100 be set to a public IP address?
I have obtained a /29 range of public IP addresses from my ISP. That /29 network resides on the LAN interface of the cable router/modem/whatever you want to call it. At the moment I am using a Zy...
Dec 01, 2025Guru - Experienced User
If your going to have two routers on the same line, then use the host routers DMZ or IP Pass thru to help with double NAT issues.
