drkayak99
Sep 19, 2024Aspirant
cannot disable broadcast of 6GHz SSID on RS700S
Hi,
Because none of my devices support 6GHz, I want to disable broadcast of that SSID. I uncheck 'Enable SSID Broadcast' for the 6GHz network under WIreless Setup, and click on Apply. Inevitably, on future visits to the router pages, I see that 'Enable SSID Broadcast' is once again checked for the 6GHz network. Thanks.
-Paul
It now appears that the 'Enable SSID broadcast' is staying unchecked for the 6GHz network, which is what I wanted.
Sorry for wasting people's time!
Is the Front 6Ghz LED turn OFF and remain OFF after you disable the 6Ghz SSID network?
- drkayak99Aspirant
Enjoy. 📡
