ninja661
Aug 28, 2026Luminary
Cannot reach certain websites
I have been trying to reach Distrowatch.com and the RS200 I have some odd reason refuses to connect to the website. If I bypass the freaky thing and connect directly to my ISP modem, the website com...
Aug 28, 2026Guru - Experienced User
You're right. You "shouldn't" have to change the DNS. But it wouldn't be the first time the DNS from and ISP didn't pull up when ran through a 3rd party router.
Its a pretty easy test to change DNS. Make sure to do it for both IPv4 and IPv6 if you have IPv6 enabled.
Might even be worth checking if there's a faster DNS for your area while you're at it.
I use this site. I don't always pick the fastest but it gives a good idea of what speeds are like.
https://dnsspeedtest.online/
