Rugershooter
Dec 16, 2025Tutor
Currently I'm on old firmware rebooting the router 1-3 times a day
Netgear has had me provide dumps, run beta firmware, replaced the router, separate 2.4 devices in isolation of the guest network, reset factory settings, etc. They wanted me to run a different set o...
Dec 17, 2025Guru - Experienced User
So what is the main issue or problem that causes you to have to reboot the router?
What is happening?
What brand and model# devices do you have connected in total?
What Firmware version # is currently loaded?
Ohters have mentioned v1.0.7.96 has worked better.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Using ISP Detected DNS or custom DNS?
Is Armor, Guest Network, SPC or IPv6 Enabled or disabled?
