Overtkill
Dec 15, 2025Tutor
DHCP assignment issues on RS700 are not fixed
Trial Firmware for me too please. DHCP assignment issues on RS700 are not fixed with the October release 1.0.9.16_2.0.106. Options also seems skimpy in the configuration settings. Thanks!!
- Jun 14, 2026
Issue resolved. BitDefender Security suite's firewall has an issue with detecting the network is a Home/Work network, and Public. Forced settings to Home/Work, and had to do this a few times on one rig, due to BD not saving the settings properly. One would think that they'd easily pull that information from Windows on install (c# System.Management "Network Category").
Additionally, it also has a "Stealth Mode" feature, that also has to be turned off.
This resolved the issue on all 3 machines.
I appreciate your help and time. And the same to WarmHelp_NTGR. :)
Thanks!
Overtkill
Jun 16, 2026Tutor
Indeed inside BitDefender. From the App:
- Protection category, in Firewall Settings.
- Type: Home/Office -should be set as default in all tabs if you are connected as such.
- The setting labeled "Use passive DHCP Mode," should be Enabled.
- On the last tab (labeled "Settings"), Click "Edit Stealth Settings," and Disable "Ethernet."
- Click OK, and close the BitDefender window.
- I would repeat the above settings changes. Settings seemed not to take on the first go around.
This resolved all DHCP issues here on all 3 machines that exhibited the issue on a weekly interval.
