Dyggy
May 13, 2025Aspirant
Disable 5Ghz and 2.4Ghz band
You should definitely add this feature back because it does cause issues with specific devices. Specifically in my senerio i play a lot of vr games with full body tracking. The trackers themselves c...
Dyggy
Every router I've ever had i have had to disable the 2.4ghz radio weather it be netgear or another competing company. It will never not cause issues in my scenario. I feel this is a completely necessary option to add on if possible.
