Champnet
Aug 13, 2026Tutor
Email logs
New poster so bear with me. Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the opti...
Champnet
Aug 15, 2026Tutor
Interesting they look very similar machines, can you confirm firmware version V1.2.7.2
schumaku
Aug 16, 2026Guru - Experienced User
Its not possible to compare the version numbers of the various RS router models and variants. In the case of RS300 and RS280, current firmware seems to be v1.2.7.2 indeed.
- ChampnetAug 16, 2026Tutor
Thanks, It was only the RS300 and RS280 I was comparing as they look very similar routers.
Not sure where to look next, hoping the menu system is dynamic based on something I've set or not set up.
