Champnet
Aug 13, 2026Guide
Email logs
New poster so bear with me. Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the opti...
Aug 17, 2026Guru - Experienced User
What Region are you located? USA or EU, or elsewhere?
- ChampnetAug 18, 2026Guide
UK
- FURRYe38Aug 18, 2026Guru - Experienced User
Ok, Thank you.
Sorry to say that I've been told that your region seems to have cyber security policies in place that caused NG to remove Email logs from the FW. Seems to have been removed a while back. I presume NG has to play by the rules for certain regions.
Never heard of local cyber security policies and I've been running large IT systems for many years.
Looking at the logs there's very litle information, gone are the multiply lines of "[DoS attack: STORM]" etc so I reckon I can manage without them.
What has caused a major problem is, I assume, the trial of Armor. All devices with an Public/ Private Network option we're changed to Public. I couldn't remove Armor but I did manage to disable it.
Thanks for your help....
