Champnet
Aug 13, 2026Guide
Email logs
New poster so bear with me. Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the opti...
Champnet
Aug 18, 2026Guide
UK
Aug 18, 2026Guru - Experienced User
Ok, Thank you.
Sorry to say that I've been told that your region seems to have cyber security policies in place that caused NG to remove Email logs from the FW. Seems to have been removed a while back. I presume NG has to play by the rules for certain regions.
- ChampnetAug 18, 2026Guide
Never heard of local cyber security policies and I've been running large IT systems for many years.
Looking at the logs there's very litle information, gone are the multiply lines of "[DoS attack: STORM]" etc so I reckon I can manage without them.
What has caused a major problem is, I assume, the trial of Armor. All devices with an Public/ Private Network option we're changed to Public. I couldn't remove Armor but I did manage to disable it.
Thanks for your help....
- FURRYe38Aug 18, 2026Guru - Experienced User
Maybe something having to deal with what router mfrs have to work with for regional policies and would have to be followed. I know, seems odd that email logs feature would be effected, however maybe something has happened over the years that caused email logs to be come exploited by nefarious actors. Thus triggered some security concern at some level in your region. Noticed over the years that regional issues have cropped up and seems to have odd things seen across various products. Wifi is another item. Some of these were maybe not of a concern over 10 year ago.
Email feature is a code base in FW and would be seen across all model routers in the NA region. For those that are restricted in these other regions, would be removed for those regions.
Something to be aware of as well on RS router that should help with nefarious port scans, Protection Engine:
NETGEAR Nighthawk/Orbi - Protection Engine Feature FAQ | NETGEAR Communities
Something you can test at grc.com and SheildsUp! test there.
