Champnet
Aug 13, 2026Guide
Email logs
New poster so bear with me. Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the opti...
Alexander21
Aug 18, 2026Aspirant
You may want to check whether the RS300 has the latest firmware installed, as the interface and available options can vary by firmware version. If the Email Logs option is missing under Advanced > Security, it may also be restricted or moved in the newer firmware. Checking the official RS300 manual or support page for your exact firmware version should confirm where the setting is located.
- ChampnetAug 18, 2026Guide
Thanks,
I've jiust been informed by FURRYe38 that the UK region "Seems to have cyber security policies in place that caused NG to remove Email logs from the FW , therefore no matter which firmware version I use or which manual I read the option is not going to be available. Still there on my D6400 though............
