Champnet's avatar
Aug 13, 2026
Email logs
New poster so bear with me.
Just upgraded from an old D6400 to a brand new RS300. On the D6400 I could regularly email logs but on the RS300 I can't find the option. All on-line advise says the option to set iu up should be in Avvanced, Security, the next option following Schedule. I don't have that option, I'm now wondering if it 'appears' after setting an option that hasn't yet been set.
Thanks for any advice................
  • Talking to collegues, we agree  the only system security that applies at this level is the Data Protection Act 2018, this Act prevents the misuse of data which doesn't seem to apply in this case.
    Netgear Support are now looking into the problem, Ive just sent further details............
  • Finally a comment from Netgear Support  "I would recommend performing a factory reset on the RS300"
    As the RS300 seems to offer no improvment over the D6400 I might just return the new box as being a waste of time and money. In the meantime I'll ask about the Region security block............
  • FURRYe38's avatar
    Ya, FR is not going to fix this. This is a regional security issue that NG has to follow from what I'm told.
    If the RS won't work for you needs, then ya, find something else that does. Old stuff I presume won't have this limitation and new stuff may see this issue.
    Good Luck.
