RealSensei's avatar
May 27, 2025
Experience brief disconnections
Hello,
I am experiencing a similar problem, primarily on my mobile phones. I have already disabled the features you mentioned and all related protections, and I have also split my Wi-Fi network. However, my smartphones continue to experience brief disconnections, especially when playing games such as Clash of Clans.
    Similar to what?
    If you are following on from an earlier con versation, I'm afraid the link to that has evaporated.
    Which Netgear device is this?
    Disconnect from what? WiFi? Mobile signal?
    The general advice is that mobile devices don't play nicely with games.
    • RealSensei's avatar
      RealSensei
      Tutor
      Oops, yeah, looks like that chat vanished.
      So, this other guy was saying his phone's Wi-Fi kept dropping signal, but it wouldn't stay down—it'd be back up in seconds.
      I previously used the Netgear RS200, which offered high speeds. However, I experienced internet connectivity problems, particularly with phones. Testing revealed speeds of approximately 940 Mbps.
      To avoid further complications, I returned the previous product to Best Buy and purchased the RS300 model instead, effectively resolving the issue. While minor inconsistencies occasionally occur, performance has been largely reliable since disabling all subscription-based protection and isolating signal sources. Forgot to mention that i went through all the troubleshooting and even resetting the router without success.
      My Nergear R6400v2 was great, never any connection problems. Everything ran smoothly, but top speed was only 208 MBps.
