batemanr
Sep 19, 2025Aspirant
Failed logins to my QNAP NAS from my Netgear BE9200
With Armour enabled I am seeing numerous failed login attempts reported by all of my QNAP NAS devices The problem is bad enough that my QNAPs are blocking the source IP of my router, which is the...
batemanr
Been there,done that.
The issues are:
- Why can't Netgear answer definitively?
- Since the issue goes away with Armor disabled, why isn't there an option for me to configure "hands off"?
It is very scary to me that Netgear apparently does not know what the firmware they release for our devices actually does...
Sep 19, 2025Guru - Experienced User
You may need to disable Armor while NG takes a close look into this. Something to keep in contact with NG support about.
Do you already have a case #?
