batemanr
Sep 19, 2025Aspirant
Failed logins to my QNAP NAS from my Netgear BE9200
With Armour enabled I am seeing numerous failed login attempts reported by all of my QNAP NAS devices The problem is bad enough that my QNAPs are blocking the source IP of my router, which is the...
batemanr
I have disabled SSH on all of my NAS, hoping my router default gateway will no longer get blocked!
-I will enable SSH if I want to use it, then disable again..
Sep 19, 2025Guru - Experienced User
So you think that the SSH feature on the NAS is causing this interaction with Armor if enabled on the RS router?
