SteelerNights
Jul 10, 2025Guide
FYI, uPNP Port forwarding has Nat Loopback issues with DDNS... Use manual entering of ports instead
To anyone trying to access devices on your network via DDNS... Using uPNP for automatic port forwarding is resulting in DDNS failure behind the router, although devices can be connected outside ...
gramwilliams
Jul 10, 2025Aspirant
FYI: uPNP with DDNS can cause NAT Loopback issues. It's better to set ports manually for a stable connection.
