SteelerNights
Jul 10, 2025Guide
FYI, uPNP Port forwarding has Nat Loopback issues with DDNS... Use manual entering of ports instead
To anyone trying to access devices on your network via DDNS... Using uPNP for automatic port forwarding is resulting in DDNS failure behind the router, although devices can be connected outside ...
Jul 11, 2025Guru - Experienced User
What model router do you have?
BH_C
Jul 12, 2025NETGEAR Expert
Sorry, I meant to ask SteelerNights which modle s/he has. But now I figured SteelerNights has RS600 specified as his/her device.
What is the firmware version running on your RS600 SteelerNights ?
- SteelerNightsJul 12, 2025Guide
BE17000, but not sure how that's different from RS600
- BH_CJul 12, 2025NETGEAR Expert
Do you have the firmware version? Thanks.
1.0.1.90
