SteelerNights
Jul 10, 2025Guide
FYI, uPNP Port forwarding has Nat Loopback issues with DDNS... Use manual entering of ports instead
To anyone trying to access devices on your network via DDNS... Using uPNP for automatic port forwarding is resulting in DDNS failure behind the router, although devices can be connected outside ...
gramwilliams
Jul 12, 2025Aspirant
FYI, uPNP port forwarding can cause NAT loopback problems with DDNS. It’s better to manually enter port forwarding settings to avoid these issues.
SteelerNights
Jul 12, 2025Guide
Why did you just repeat everything I wrote in my post? Are you trying to get someone to mark it as a solution? Do imaginary internet points mean that much to you?
