cityx
Oct 08, 2025Aspirant
GL.INET 5GHZ get WIFI 7, RS700 it doesnt (wifi 6)
My travel router GL.INET Slate 7 looks like it works much better than my RS700 on firmware 1.0.7 Both same channel and WPA3 My Samsung Galaxy S24U gets Wifi 6 if it connects to Slate 7, but it conn...
- Oct 08, 2025
Errata correction: with Slate 7 my S24U connects in WIFI 7, RS700 connects in WIFI 6
Oct 08, 2025Guru - Experienced User
Have you tried more recent FW? New - RS700S Firmware Version 1.0.9.6 Released | NETGEAR Communities
Something you'll need to contact NG support about then and let them know what your seeing. IF it is a FW issue, they'll need to get it fixed. Nothing we can do here from the forum side.
Good Luck.
