cityx
Oct 08, 2025Aspirant
GL.INET 5GHZ get WIFI 7, RS700 it doesnt (wifi 6)
My travel router GL.INET Slate 7 looks like it works much better than my RS700 on firmware 1.0.7 Both same channel and WPA3 My Samsung Galaxy S24U gets Wifi 6 if it connects to Slate 7, but it conn...
cityx
Its a pity GL.Inet doesn't have a router with 320Mhz support in Wifi 7, because I will from them instantly and dump this RS700. Asus is full of bugs, TP-LINK crap, now NEATGEAR another bugged firmware and a uselesss support.
Oct 08, 2025Guru - Experienced User
Again, fixes don't come over night. You'll need to find something else that works for you if your really wanting WiFi7. Orbi BE series is currently supporing 7. Galaxy 25s working in MLO on my system.
Good luck.
