cofresi59
Mar 03, 2026Aspirant
Having Problems with OpenVPN for Mac
I recently upgraded my ASUS router to a Netgear RS700. I configured the OpenVPN service to TUN mode on UDP port 12973 and TAP mode on 12974. Clients will use VPN to connect to the internet and the ho...
cofresi59
Hi again,
I opened the config file with Text Edit, and this is what I found:
client
dev tun
proto udp
remote xxxxxxxx.mynetgear.com 12973
resolv-retry infinite
nobind
persist-key
persist-tun
cipher AES-128-CBC
comp-lzo
verb 5
dhcp-option DNS 68.94.156.11
dhcp-option DNS 68.94.157.11
I noticed that the DNS is different from the DNS I use, which is 1.1.1.1 and 1.0.0.1. Would that make a difference?
- StephenBMar 03, 2026Guru - Experienced User
cofresi59 wrote:
dev tun
proto udp
remote xxxxxxxx.mynetgear.com 12973Interesting. Your config file is using TUN. The file I posted (using TAP) is the Mac config file from my Orbi 870.
Changing to TAP is worth a try - just save the original file, so you can put it back if needed.
The DNS servers in the config file are hosted by AT&T. It should be fine to change them to Cloudflare. If that still fails, then you could also try just removing those lines.
