tonyw97007
Feb 23, 2026Aspirant
how to setup secure dns
I cannot find a way to get my RS700 router to use secure DNS? any ideas?
Feb 24, 2026Guru - Experienced User
Are you just wanting to use a 3rd party DNS? If so, thats pretty easy.
Log in through the browser and go to the internet tab. That's where you'll find the default DNS settings that you can change to whatever you prefer. If you use IPv6 (and your isp supports it), you'll also want to change it for IPv6 too.
