ciscokid624
Aug 06, 2026Aspirant
I have a RS600 that drops WiFi signal daily like 4-5 times every day
I have a RS600 that drops WiFi signal daily like 4-5 times every day since purchased a month ago. My old X10 never dropped signal. I have two EXS27 extenders around my home and will unplug those to s...
- Aug 14, 2026
It was being caused by the NORDVPN setting on my iphone. Make sure your techs know when someone has this issue. Other items without the VPN, were still getting WiFi😱. I figured that out myself thank you just before we were going to unplug everything AGAIN. All good and stable for now.
Aug 06, 2026Guru - Experienced User
What firmware is loaded on the RS router?
How big is the home in sq feet?
What channels are you using on the RS router?
Distances between the RS router and the EXS extenders?
What brand and model# is the ISP modem that the router is connected too?
I've not seen this with my RS600, though I don't use EXS extenders.
ciscokid624 wrote:I have a RS600 that drops WiFi signal daily like 4-5 times every day since purchased a month ago. My old X10 never dropped signal. I have two EXS27 extenders around my home and will unplug those to see if that's the issue. I've read disable IPV6 so I'll try that also
- ciscokid624Aug 14, 2026Aspirant
- FURRYe38Aug 14, 2026Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/19952/How-do-I-back-up-or-restore-the-settings-configured-on-my-NETGEAR-router
Enjoy. 📡
