RealSensei
Aug 10, 2025Tutor
I have experienced similar challenges that persist intermittently
In regard to this issue, has it been resolved? I have experienced similar challenges that persist intermittently, although they do not occur on a daily basis.
Aug 10, 2025Guru - Experienced User
What model NH router do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What problems are you having with this product?
