robmartinez108
Oct 15, 2025Tutor
I just spent $400 on a new Netgear Nighthawk router
I just spent $400 on a new Netgear Nighthawk router only to find out it has the same problem as the old out of service RAX43 router. If it’s a Windows issue, I don’t think MS is too interested in ...
- Nov 05, 2025
It has been several days without any issues accessing Readyshare after I disabled the Protection Engine feature on my Netgear RS600 router. I am marking this thread as solution found but I would have preferred to keep the Protection Engine enabled. Hopefully, in the future a fix can be found so as to be able to use both Readyshare and Protection Engine at the same time. Thanks to FURRYe38 and the others who helped to narrow down the cause of the issue.
robmartinez108
Oct 18, 2025Tutor
I never did have this problem with 23H2. I also checked ‘fdrespub’ but that service is running.
Oct 18, 2025Guru - Experienced User
Possible something MS may have introduced.
What brand and model of the USB drive is connected to the RS router?
What version of Windows this this?
Is SMBv1.0 enabled on the Windows PC?
