robmartinez108
Oct 15, 2025Tutor
I just spent $400 on a new Netgear Nighthawk router
I just spent $400 on a new Netgear Nighthawk router only to find out it has the same problem as the old out of service RAX43 router. If it’s a Windows issue, I don’t think MS is too interested in ...
- Nov 05, 2025
It has been several days without any issues accessing Readyshare after I disabled the Protection Engine feature on my Netgear RS600 router. I am marking this thread as solution found but I would have preferred to keep the Protection Engine enabled. Hopefully, in the future a fix can be found so as to be able to use both Readyshare and Protection Engine at the same time. Thanks to FURRYe38 and the others who helped to narrow down the cause of the issue.
robmartinez108
Oct 18, 2025Tutor
The drive is SSD. Most of the time after 20 minutes but not always. Sometimes it stays connected for up to an hour. Sometimes if I leave the PC on long enough it will reconnect on its own.
- FURRYe38Oct 18, 2025Guru - Experienced User
Ok, setting up a 250Gb SSD drive I have here on my RS600 and will have one ethernet connected PC, 24H2, and see what I can find. PC is connected to the 10Gb ethernet port since it has a 10Gb ethernet adapter.
FW is v.22
Will check this in a while and monitor.
