robmartinez108
Oct 15, 2025Tutor
I just spent $400 on a new Netgear Nighthawk router
I just spent $400 on a new Netgear Nighthawk router only to find out it has the same problem as the old out of service RAX43 router. If it’s a Windows issue, I don’t think MS is too interested in ...
- Nov 05, 2025
It has been several days without any issues accessing Readyshare after I disabled the Protection Engine feature on my Netgear RS600 router. I am marking this thread as solution found but I would have preferred to keep the Protection Engine enabled. Hopefully, in the future a fix can be found so as to be able to use both Readyshare and Protection Engine at the same time. Thanks to FURRYe38 and the others who helped to narrow down the cause of the issue.
Nov 01, 2025Guru - Experienced User
Let us know after 3 days please.
robmartinez108 wrote:Yesterday I disabled the Protection Engine and so far, I haven’t come across this issue. I will give it some more time and report back.
robmartinez108
Nov 05, 2025Tutor
- FURRYe38Nov 05, 2025Guru - Experienced User
Good to hear. I'll pass this on to NG for review.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
