Rjmer739
Nov 29, 2025Follower
i noticed that my ipv4 lease expires at 47000+ days and it causes my internet to crash
I'm having a similar issue. I noticed when going into the router settings Advanced > Advanced home > Connection Status i noticed that my ipv4 lease expires at 47000+ days and it causes my internet t...
LaddieParker
Nov 30, 2025Guide
I had exactly the same problem as you describe. See the link below.
It was fixed with a trial firmware.
- ckamDec 01, 2025Aspirant
I am facing the same issue since few days ago, assuming the ISP is the one causing the problem until I saw your thread posted in Nov.
Since the thread is locked after you marked the issue has resolved, shd I open a new thread about the problem or else ?- FURRYe38Dec 01, 2025Guru - Experienced User
What model# is your router?
Since the thread is locked after you marked the issue has resolved, shd I open a new thread about the problem or else ?- ckamDec 01, 2025Aspirant
RS700
