treefrog7
May 13, 2025Aspirant
I'm having the same problem on my RS300 with firmware V1.0.1.90
Were you able to solve this issue? I'm having the same problem on my RS300 with firmware V1.0.1.90.
treefrog7
That's weird, I posted a comment on the thread below, but somehow that thread is now locked and my comment is its own thread.
RS300 Wifi Lag Problems | NETGEAR Communities
At any rate, when I'm on a video call over wi-fi on my new RS300, there is a lot of lag. It's better on the 6 GHz band, but pretty bad on the 5 GHz, even when my laptop is inches away from the router. Not all of my devices support 6 GHz, unfortunately. My old router was a Netgear R7000 and it never had these issues.
As mentioned above, the firmware version is V1.0.1.90.
My cable modem is a Netgear Nighthawk CM2050V-100NAS. The cable from the modem to the router is the one that came with the RS300. I'm not sure how to tell what kind of cable it is.
I manually updated the firmware to the V1.0.1.90 version to see if it would help, but no luck. I did not do a reset/from-scratch-setup after the firmware update.
