JDGamer
Jan 20, 2026Aspirant
I'm not savvy enough to know what "bufferbloat" is
I'm not savvy enough to know what "bufferbloat" is, but I have been having a HORRIBLE time gaming with this router. I have Frontier Fiber FiOS at 2 gigabit speed, and have to literally reboot the rou...
JDGamer
Apr 08, 2026Aspirant
Update : finally reached out to ISP and went up in support tier. At first they said “things looked fine” on their end, but I elaborated how it seemed to ONLY have issues during gaming where the entire network would crash (router admin page was still accessible but internet across all devices was usually down for a bit right after online multiplayer gaming round of any kind would start). That seemed to get them to actually check the logs…
And so it looks like the culprit is probably faulty ONT hardware (tech said diagnostic had shown 50+ disconnects just in the past 2 days). They are coming out to replace and swap out older cat5e run from ONT to router inside the house tomorrow afternoon, so we will see if that fixes things.
- FURRYe38Apr 08, 2026Guru - Experienced User
Thanks for the update. Glad they seem to be proactive on this. Let us know how it goes.
You might get a CAT6A STP cable in between the ONT and your RS700. What I use with mine.
