GeorgeHow
Sep 19, 2026Aspirant
iPhone Wifi Calling on Airplane Mode
I normally use airplane mode on my iPhone when at home.Wifi Calling is enabled. Recently all three of our iPhones are no longer able to make and receive wifi calls (popup "No Network Connection" sel...
schumaku
Sep 19, 2026Guru - Experienced User
GeorgeHow wrote:I normally use airplane mode on my iPhone when at home.Wifi Calling is enabled. Recently all three of our iPhones are no longer able to make and receive wifi calls (popup "No Network Connection" select cancel of disable airplane mode") .
Of course, and works as expected. Nothing new ...
FMI: Use Airplane Mode on your iPhone, iPad, Apple Watch, and Apple Vision Pro says:
With Airplane Mode, you can turn off cellular and Wi-Fi on your device during a flight.
Turn on Airplane Mode
- On your iPhone, iPad, or Apple Vision Pro, open Control Center and tap the Airplane Mode button. This turns off all radios except for Bluetooth. Turning on Airplane Mode can also help to save battery, lower roaming charges while traveling, and force a signal refresh.
- On your Apple Watch, press the side button to open Control Center, then tap the Airplane Mode button. In watchOS 9 and earlier, swipe up from the watch face to open Control Center.
If the airline allows it, you can still use Wi-Fi and Bluetooth in Airplane Mode. If you turn off Bluetooth while you're in Airplane Mode, your device turns off Bluetooth the next time that you turn on AirPlane Mode.
Yes, it's a little bit obscure to most readers what that last two sentences whould tell us. A possible anser is in
Choose iPhone settings for travel
You can also turn Airplane Mode on or off in Settings
. When Airplane Mode is on, the Airplane Mode icon
appears in the status bar.
Turn on Wi-Fi or Bluetooth while in Airplane Mode
If your airline allows it, you can use Wi-Fi or Bluetooth while in Airplane Mode.
- Open Control Center, then turn on Airplane Mode.
- Tapto turn on Wi-Fi or to turn on Bluetooth.
- If you turn on Wi-Fi or Bluetooth while in Airplane Mode, it may still be on the next time you return to Airplane Mode. You can turn it off again in Control Center.
Saying that much: Even in Airplane mode, you can explicitly turn on Wi-Fi and/or Bluetooth.
GeorgeHow wrote:BTW, in the mobile Nighthawk App, I can connect to the router locally or vial Anywhere Access. What is the preferred access when at home?
As long you are within your home WiFi coverage, and not on some other VLAN or VPN, locally is the preferred way.
GeorgeHow
Sep 20, 2026Aspirant
StephenB (Guru?)
Wifi call prompting "no network connection disable airplane mode" message occurs while the Wifi is connected and airplane mode is enabled. The control center should present the "cellular carrier - Wifi" when things are working. In this case, it is not displayed. Note that I am still able to do web browsing in this configuration - so network connection is available.
Googled my situation - here is Google AI's reply:
"The culprit is likely a bugged IPsec ALG or firewall implementation in recent Netgear firmware which blocks the secure tunnels required for carrier Wifi calling. Other Nighthawk RS200 users have reported this exact issue on Netgear forums. While you wait for the engineering team, a few specific router configurations can bypass the block. 1 Disable Port Scan and Dos Protection. 2 Turn off Smart Connect. 3 Check for IPsec ALG (Beta Firmware).
I did connect with the Netgear support last night and they are working on a solution. I'm very happy with the Netgear support team and also pretty happy with Google AI.
Kind Regards George How
- StephenBSep 21, 2026Guru - Experienced User
Please follow up when you have a solution.
I think Google has the IPsec ALG bit wrong.
There is SIP ALG. If that is enabled, then definitely disable it. The manual says that the SIP ALG is enabled by default - which is really unfortunate, since modern SIP infrastructures don't need it, and that ALG can definitely interfere with VoIP calls.
See page 86 here for info on disabling it:
- https://www.downloads.netgear.com/files/GDC/RS200/RS200_RS150_UM_EN.pdf
