retired-sysprog
Sep 14, 2025Tutor
I've just bought a RS200 to replace my R7800
 Interesting ... I've just bought a RS200 to replace my R7800 and I get a very similar problem.     I find everything connected to the router loses internet connection but I can still ping the router ...
Sep 14, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Armor, IPv6, Smart Parental Controls or Circle, Protection Engine and Traffic Meter.
