notmywookiee
Jun 07, 2025Follower
Just upgraded to fios 1gb. RS700 wifi uploads are like 50 to 120 mb/s
so having what appears to be same issue. just upgraded to fios 1gb. RS700 wifi uploads are like 50 to 120 mb/s . had an old orbi rbk50 around and it gets max wire speeds and consistent up down on ...
Jun 08, 2025Guru - Experienced User
Who is the ISP?
What brand and model# is the ONT the RS router is connected too?
Be sure your using good quality LAN cable between the ONT and RS router. CAT6A STP is recommended.
