Redlight
Dec 15, 2025Aspirant
LAN 10G LED is red but internet seems to be working fine.
Cable is good. Any suggestions about why LED is red? I have a Nighthawk RS700 BE 19000 wifi 7 Router, firmware V1.0.9.16_2.0.106. Should I just ignore the red LED?
Dec 15, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
