Redlight
Dec 15, 2025Aspirant
LAN 10G LED is red but internet seems to be working fine.
Cable is good. Any suggestions about why LED is red? I have a Nighthawk RS700 BE 19000 wifi 7 Router, firmware V1.0.9.16_2.0.106. Should I just ignore the red LED?
Dec 16, 2025Guru - Experienced User
Redlight wrote:Should I just ignore the red LED?
CrimpOn wrote:Any chance the LED could be Amber?
FWIW, I often find that Amber LEDs look Red in some lighting conditions.
Like CrimpOn, I am thinking that the device connected to this port doesn't support 10G. If so, that is not a problem, just an expected status.
