Redlight
Dec 15, 2025Aspirant
LAN 10G LED is red but internet seems to be working fine.
Cable is good. Any suggestions about why LED is red? I have a Nighthawk RS700 BE 19000 wifi 7 Router, firmware V1.0.9.16_2.0.106. Should I just ignore the red LED?
CrimpOn
Dec 15, 2025Guru - Experienced User
Any chance the LED could be Amber?
What device is connected to this port?
Redlight
Dec 21, 2025Aspirant
Yes, I think I was wrong. The light is amber, which likely indicates my Xfinity 1 Gbps plan is working correctly. It's connected to my Xfinity modem.
Thank you very much for your help.
