Kyleli
Jun 02, 2026Aspirant
NAS under the 1G, and PC under the 10G Lan
I run into the same issue, and update the latest FW, but no work, NAS under the 1G, and PC under the 10G Lan, but the download speed is about the 50Mb/s (110Mb/s should be the right one for 1G, but t...
Jun 03, 2026Guru - Experienced User
Kyleli wrote:NAS under the 1G, and PC under the 10G Lan,
What speed is the PC actually negotiating? What multigig NIC card is it using? If you are paying for multigig internet service, are you getting that speed using speedtest?
How are you measuring the network speed between the NAS and the PC? iPerf3 is a good tool (and can be installed on both the PC and the NAS).
Have you tried connecting the PC to one of the gigabit LAN ports? If you do, what speed are you getting?
