Im4blues
May 06, 2026Aspirant
Netgear Nighthawk RS700S and am having issues with connecting to my office VPN
I just purchased a new Netgear Nighthawk RS700S and am having issues with connecting to my office VPN. I can connect to the VPN and see all the available drives but cannot access them. I am able to c...
CrimpOn
May 06, 2026Guru - Experienced User
The consumer router has nothing to do with connecting to an office VPN. That is entirely between the VPN software installed on the client computer and the office VPN. The router is not even aware that a VPN is involved.
VPNs are sensitive to the IP subnet of the local network and the network revealed by the VPN. Could you please take a minute to discover:
- The IP subnet created by the RS700S router. This can be found in the router web management LAN setup page.
The default for Netgear routers is 192.168.1.1 with a subnet mask of 255.255.255.0, but there are factors which can cause it to be set to something else. - The IP subnet for the VPN network where those office drives exist. Perhaps the IT service provider can help with that.
- If they are both the same IP subnet, that can interfere with common operations
It would be useful to know which VPN package the office has installed and how you typically connect to the office drives.
May 07, 2026Guru - Experienced User
CrimpOn wrote:The default for Netgear routers is 192.168.1.1 with a subnet mask of 255.255.255.0, but there are factors which can cause it to be set to something else.
Im4blues: You could try changing it to 192.168.168.1 (same subnet mask), and then reboot the router. See if that makes any difference.
