Im4blues
May 06, 2026Aspirant
Netgear Nighthawk RS700S and am having issues with connecting to my office VPN
I just purchased a new Netgear Nighthawk RS700S and am having issues with connecting to my office VPN. I can connect to the VPN and see all the available drives but cannot access them. I am able to c...
Richardj1864
May 08, 2026Aspirant
The issue can also be your ISP-provided modem. Shut off your RS700 router, and then unplug your modem from power for 60 seconds, then plug modem back in to power. After the modem finishes booting and is back online, then turn the RS700 back on.
If that doesn't work, you can download the latest firmware for the RS700 and manually install it. You should already have it installed to make sure all security updates are in place, along with bug fixes.
