johnnydiesel
Dec 05, 2024Aspirant
Netgear RS500-NAS after power cycle only ethernet works
Brand New RS500-NAS purchased. Setup and all works well and in use for about 5 days. Power cycled the unit and the ethernet came back on, but the wireless was off. Looked in config, and saw wireless ...
Dec 05, 2024Guru - Experienced User
Any anyone pushed the wifi radio button?
What FW version is loaded on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channel configurations are currently set on the router?
- johnnydieselDec 05, 2024Aspirant
No, it is on top of our kitchen cabinet and my wife cannot even reach up to it.
The latest FW is loaded and it was updated by me requesting, and is set to automatic updates.
TMobile Home internet G4AD
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Using the best CAT 6 cable between router and home internet.
pre set by router.
Any Wifi Neighbors near by? If so, how many?In a very rural area. Neighbors wifi is distant and very weak but on a separate channel looking at wifi survey when setting up and after 1 week in use.
Sorry Tmobile G4AR Router Modem utilized. It is on separate channel broadcasting also for no interference.
- FURRYe38Dec 05, 2024Guru - Experienced User
What is the distance between the ISP modem and the RS router?
So lets disable the WiFi radios on the ISP modem and see if this happens again.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...What channel configurations are currently set on the router and ISP modem exactly?
The router is 40 feet away from the TMobile gateway connected via ethernet
Cannot turn off the radios on TMobile gateway unless using some foreign app and software. Against mobile policy.
I Using channel 3 on one device and channel 11 on the other. 3 is fixed on TMobile and can not be changed.
The warning message in the config of the RS-500 has a warning in wifi area that says with an exclamation point - The wifi is off. This happens after any reboot or power off.
I have to go into config to turn it back on.
This thing worked perfect for almost two weeks and then bam, all I did was power it off and on.
Now this.
