Troubleshooting
2 TopicsRS300 Rapidshare unable to create folders
I just replaced my old router with the RS300 wifi7 tri-band. Network works grate but when I tried to add my 14tb Seagate external hdd,I had my first issue. Router setup USB enabled Hdd recognized shows 14tb And this is where the wheels fall off. When I go into rapidshare to create a folder, everything is grayed out. Router SW/FW info Firmware Version V1.0.1.60 GUI Language Version V1.0.0.449 Protection Engine Version 2.2.214.4/1.0.0.2061 Operation Mode Router CPU Load CPU1: 9.56% CPU2: 8.96% CPU3: 9.75% CPU4: 9.17% Memory Usage (Used/Total) 663MB/1999MB Flash Usage (Used/Total) 423MB/512MB Hdd Seagate expansion 14tb (works great when connected to a computer. Any help would be great.443Views0likes1CommentNetgear RS500-NAS after power cycle only ethernet works
Brand New RS500-NAS purchased. Setup and all works well and in use for about 5 days. Power cycled the unit and the ethernet came back on, but the wireless was off. Looked in config, and saw wireless off. I power cycled router again, and wireless is still off but the ethernet is on. I went into wireless the config via ethernet, and saw the wireless is highlighted and off. I turned on the wireless. After the config change reboot the unit power cycled and the wireless came back on. I power cycled again, and ethernet and wireless came back on. I regularly turn off my power to all internet in my home when not there. Since I have had this unit, it has worked well, but the question is, how long till this happens again? The radios in the router failed to start on their own and turned off wireless in configuration on it's own. Is this a bad unit? Is this router capable of being power cycled when needed for use?782Views0likes6Comments
