G76's avatar
G76
Follower
Dec 07, 2024
RS300 Rapidshare unable to create folders
I just replaced my old router with the RS300 wifi7 tri-band.
Network works grate but when I tried to add my 14tb Seagate external hdd,I had my first issue.
Router setup
USB enabled
Hdd recognized shows 14tb
And this is where the wheels fall off.
When I go into rapidshare to create a folder, everything is grayed out.
Router SW/FW info
Firmware Version
V1.0.1.60
GUI Language Version
V1.0.0.449
Protection Engine Version
2.2.214.4/1.0.0.2061
Operation Mode
Router
CPU Load
CPU1: 9.56% CPU2: 8.96% CPU3: 9.75% CPU4: 9.17%
Memory Usage (Used/Total)
663MB/1999MB
Flash Usage (Used/Total)
423MB/512MB
Hdd
Seagate expansion 14tb (works great when connected to a computer.
Any help would be great.
1 Reply
