olegeezer's avatar
Feb 03, 2025
netgear RS700S router and 320MHz
Hello. I have the RS700S router. I have intel Killer BE1750xw wifi card capable of handling 320MHz.
I have searched my RS700S router in 192.168.1.1 for an area that I can set it to 320Mhz. Does anyone out there know what to do to set the RS700S to 320MHz ??  I have the latest netgear firmware V1.0.7.96. I have 1.2Gigs fiber-optic internet service. So how do I set the 320MHz in my router?  Thanks, Matt
    • olegeezer's avatar
      olegeezer
      Guide
      Hello. In the RS700S manual, it lists the 320MHz but I cannot find any area in 192.168.1.1 where I can select the 320MHz.
      With the RS700S being Wifi 7 capable, it should handle 320MHz. This RS700S has out-performed all my expectations. I don't understand why netgear has not provided for selecting the 320MHz.
      Thanks, Matt
      • FURRYe38's avatar
        What happens if you disable Smart Connect and check the Up To Speed seen on the RS web page under Basic tab/wireless settings?
