morrijas's avatar
Feb 06, 2026
Netgear said I need to pay for premium service for my router to work
I just got off the phone with netgear, they told me since I did not pay for premium service and security which is $300 on top of what you pay for the router it will work again, they said the new firmware in 2026 will force every new netgear router owner to pay or your router will loose internet connection.  So on top of $622 for the rs700s I have to pay $300 more for the premium service that will keep the router up is what I was told straight from netgear.  They said the new firmware will force you to pay for this and they said every router company is doing this.  So tell me if this is true or not
  • Yea but the bad thing is after the new firmware my 5ghz band was forced to 3 times slower and for the router to loose connection from the cable modem and no it is not the cable modem, the whole router would loose internet but if you look at the router all the WiFi bands are up, but the connection out is down.  Nothing has changed in the 6 months I have had this router now after the update this was the first time seeing the rs700s loose internet connection, the only thing that has changed was new netgear firmware update then all this crap started to happen, I was running perfect for 6 months tell the new firmware update, funny how combines say they test this but push out the bad firmware anyway.   It all was running perfect before the last update.  Netgear has some serious issues if they keep on pushing firmware that will not work on how the router is intended to work.  Issues with new firmware
    1. On the 5ghz band you can not go auto unless you want slow speed
    2. you have to choose new channel since auto now goes to slowest speed, I did not pay over $600 for 1/2 a router
    3. Loose internet connection at least once a day and even in the logs it is not recorded why
    The router should last more than 6 months with only 40 devices connected to it
    • coolwifi's avatar
      coolwifi
      Luminary
      I updated the firmware in my RS500 and don't have any issue. May be someone with a RS700 and updated firmware could comment.
      The 5 Ghz auto channel selection always picks the least used channel DFS or non DFS channel. It always picks DFS channel 100 in my case which impacts the range since DFS channels have lower transmit power. You should always choose a manual least congested non DFS channel in the 5 Ghz band. This hasn't changed with the latest firmware update.
      Try to restart your modem first and then the router. Did you check the web interface of your modem to see if there's any signal disconnection or weak signal issues?
