casper3725
Jun 04, 2025Tutor
Nighthawk RS600 Attached Devices list empty when it is not
My Nighthawk RS600 works fantastically, except for one minor glitch. When I first open both the app and the PC interface, both show 22 devices online, however, when I click on the button to get more...
casper3725
Jun 05, 2025Tutor
Thank you for the suggestion, as it did the trick! I made sure the router had the latest firmware and then did a factory reset. That's all it took. Now I can see all of my devices again. I appreciate the reply and will mark this as a solution. Thanks again!
Jun 05, 2025Guru - Experienced User
Glad thats all it was. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- casper3725Jun 06, 2025Tutor
Another great tip! I didn't think of that either - lol. Thanks again for all the help and advice! Have a great weekend.
- FURRYe38Jun 06, 2025Guru - Experienced User
