Bob_P_1959
Feb 18, 2026Follower
Nighthawk RS600 Dev list blank
I recently purchased a Nighthawk RS600. Everything seemed to work fine for a short time. Then the list of attached devices was blank. I restarted the router and that fixed the problem... for ONE DAY!...
Feb 19, 2026Guru - Experienced User
I have the RS600 and I've never ran into this issue.
What modem/gateway is it connected to?
Have you tried a factory reset after running into these issues?
Same here, just had my RS600 online for months last year up until January 2026, WEB UI and NH app always showed correctly for devices connected on WEB UI and app.
Bob_P_1959 One factory reset will be needed to check to see if this continues on your unit, or not. Recommend setting up with a ethernet connected PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
