ballen5678
Oct 22, 2025Follower
Nighthawk RS90
New purchase of RS90 router. Having issues with the router falling over caused by the numerious network cables attached. Does Netgear make feet or a stand that attaches to the router to keep it uprig...
Oct 22, 2025Guru - Experienced User
Can try finding some thin sized more flexable LAN cables at places like Amazon, Monoprice or Deepsurplus.
Or try this, connect one Non Managed switched behind the RS Router. Then connect all of your ethernet cables to this switch.
