connkall
Aug 12, 2025Aspirant
Nighthawk WiFi 7 Router RS700S new firmware update not alerting???
This router is advertised as "The most powerful & advanced Nighthawk router ever." yet there is no indication or alert to the latest firmware (Version 1.0.9.6), why is that? The latest firmware ...
Aug 15, 2025Guru - Experienced User
Did you make contact with NG support about the beta?
- connkallAug 15, 2025Aspirant
No, I decided to just leave it on what it came with (1.0.7.86) after reading into it more. It seems to be handling my network of 80+ devices without issues so far.
I had another problem with the registration/activation of the Netgear Armour they go on and on about but support has been useless so i've moved on.
The router works but at this point I don't feel like it was a premium upgrade to my Asus ET12, not sure if I'll try something else or keep it at this point...
- FURRYe38Aug 15, 2025Guru - Experienced User
Ok.
Good Luck.
