PeteRimkus
Jun 30, 2025Aspirant
No internet connection with new WiFi 7 (RS200)
 Hello all,  I’m attempting to replace my old AC1600 WiFi router with a new RS200 WiFi 7 router.   I can’t get to the internet (light under power light stays orange).   I checked all the cables and ha...
- Jun 30, 2025What Firmware version is currently loaded?
 Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
 Turn off and unplug modem.
 Turn on computers and rest of network.Try setting up with a PC or laptop and web browser? https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
PeteRimkus
I meant to ask : if no one has any good ideas for me, is it possible to use the Nighthawk app to remove the new RS200 and start the install again?
Jun 30, 2025Guru - Experienced User
- PeteRimkusJun 30, 2025AspirantHello, Since you asked… - Cable modem is Hitron Technologies EN2251 (provided by Spectrum).
- Firmware is 1.0.1.74
- I had been using late same sequence for shutting down and restarting.
 but … the GOOD news is that with a new CAT 6 cable I’m now connected! Thanks for suggesting something I should have considered sooner. Once I was able to get to the internet, routerlogin.net suggested a firmware update to 1.0.1.90 … which just finished. it looks like I’m good to go. Thanks again for making my try another cable. - FURRYe38Jun 30, 2025Guru - Experienced UserGlad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
